| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,744 | Unless you're using a delay flash light to check the operation of the centrifugal or vacuum advance, what's the point of using a strobe light in the first place? Stovebolt engines were designed to use a plain old ice pick type test light to do a perfectly adequate job of setting the spark timing. Jerry
