| | | Forums66 Topics128,051 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 2,190 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,190 | I'm just about to order some LED tail lights. Both my back lights were burnt out and the flasher still worked just fine with front lights only. I don't think my flasher is a LED flasher; probably a heavy duty one. Anyway, I'm sure that the LED lights will be OK with this flasher as it works with or without a load.
In shopping for LED lights, I see some are rated for 12 volts and some are rated for more than 12 volts (e.g. 18 volts). The ones rated for more than 12 volts are a bit more expensive, but I think it's a good investment since the alternator can put out up to 15 volts. The burn out problem was mentioned by some reviewers.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
