| | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Upstream of the throttle body, you would need a water manometer to measure the pressure drop- - - -just a few inches of water. The high vacuum will be found between the throttle body and the cylinder head(s). Flex plastic would be plenty rigid for the intake upstream of the throttles. You could also mock up a pipe and then cover it with fiberglass cloth and resin. Jerry
