| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,778 | Once you decide on a disc and caliper, a sneaky trick we used on the round track cars was to use air pressure to clamp the calipers to the disc- - - -then fabricate suitable brackets to mount the calipers to the spindles. Anybody with a little machining/welding experience should be able to do that without a "kit". Jerry
