| | | Forums66 Topics128,154 Posts1,056,851 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | I used pine wood on my bed.
If your angle strips don't have rust-thru spots under them you might be able to just repair that end. But be aware that getting the rust out from between the bed sides and angle strips is going to be difficult or impossible. If you don't get the rust out, it'll expand under your new paint.
With the profile the angle strips it might be simpler to get a short section of new angle strip, although I have no doubt your son could form a piece to match. It just depends on how much work he wants to do. Cutting the entire angle strip off and replacing it with new would allow you to get the rust off the bedsides where the angle strip mounts.
