7 members (Gdads51, cmayna, BC59, 55shaker, 3800GUY, Gray_Ghost, FAST55),
139
0
Mod | | | Forums66 Topics128,109 Posts1,056,253 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | I went through a couple rounds of the alignment procedure and was able to compensate for hinge looseness by changing the adjustment without the springs. It takes some head-scratching to figure out which way to shift the hinge mounting bolts - it's not clearly obvious.
