| | | Forums66 Topics128,162 Posts1,056,910 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes On a 12V system there is "bypass" wiring necessary. So the 12V coil has two inputs to indirectly power the points.. A full 12V input when starting because the starter draws so much and will rob the points of voltage/current. Then after start. the points run on a reduced/resisted voltage off the ballast input so they don't burn out.
So during start you "bypass" the ballast. Ballast drops voltage to approx 9V.
This is all accomplished by a side terminal on a foot starter switch OR an "R" terminal on a solenoid starter OR by an ignition switch with Ign 1, Ign 2 terminals.
A few years used a Looooooong folded "resistance wire" instead of a ballast resistor.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
