| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | I installed a new behind the seat fuel tank in my truck a year ago.
You do need a flexible hose to connect to the hard line from the petcock. When the truck was new it originally had one.
You can buy one from Jim Carter or other restoration suppliers for these vehicles.
I did not install a filter between the tank and the fuel pump. I figure it's a brand new tank and I'm only going to be putting fresh clean gas in it so that would probably be overkill. I also didn't want to cut all of my nice new clean fuel line.
I had the original fuel pump rebuilt it does have a small filter in it that I believe will catch whatever I need to catch.
I do not use teflon tape on any of my connections and I have had no leaks. I do, however use a permatex product called seal lock on fuel line threads
1950 Chevrolet 3100 (Ol' Roy)
