Post 'em if you got 'em...
My current setup:
Lincoln Ranger 10-LX, 250A AC/DC CC/CV power supply, powered by a Kubota 22.5 HP Diesel 3-banger. Last weekend it ate an alternator ($150.64 at the kubota dealer...ouchies..) but otherwise it's been a good machine.
Attached, or I should say soon to be attached to the supply are a Miller arc starter w/both a 150A air-cooled tig torch & 250A water cooled tig torch. I need to find some parts for the 250A torch & build a water cooler for it.
I also have a Lincoln LN-8 Wire feeder sitting in the garage, but I need a special amphenol to connect it to the 10-LX, and a 250A mig torch is on its way.
Mostly I've used the 10-LX with a bernard "shortstub" stick holder but as noted above I'm building a collection so I can do mig, tig or stick with the setup. I'm also working on constructing a trailer for this setup, as the ranger alone is 1100 lbs and it would be nice to keep everything together.
Additionally, I have a lincoln Weld-Pak 100 that I've converted to mig, and a Miller Maxstar 140 tig box that I need to replace the main board on (traded a couple computer things for it)
God is not on the side of the big armies, but of those who shoot best.
http://www.speedyoldtruck.com
