Winter is Coming
I did a quick mock up to make sure I had all the linkage, bolts, pieces etc. It's going to look pretty slick. I suspect it will perform well also. I didn't put the dual exhaust manifold on, but it will definitely be part of the build. I'm not sure if I'll use the Mallory dual point distributor and Mallory coil. They're 12v and I'd rather not convert the truck from 6v, but I might. I have a 12v generator with mount and a 12v starter so that's most of the cost and battle I think. At least the generator looks like the 6v and not a modern alternator.
