| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | It's impossible to pull the bell housing without removing the flywheel- - - - -bolts hidden underneath it. If you think you must pull the bell for some reason, put a long 4 X 4 across the fenders near the cowl, and use a 2" wide ratchet strap under the oil pan to support the back of the engine. Jerry
