| | | Forums66 Topics128,181 Posts1,057,152 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 2,243 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,243 | I will add one additional note here relaative to Gib70's comment.
The FAM says that the mounts should be in a line. That does *not* mean that the shims should necessarily be the same or proportional if you are doing a new/clean assembly.
In my case, the cab was aligned such that everything worked with variable thickness shims at all of the mounts. I could only use the math to figure out the correct new shim because I was changing an existing (notionally) correct setup.
The shims exist to correct small cab-to-cab and frame-to-frame variances, so proper shimming using traditional methods will be neccesary to get that baseline.
Theoretically a person could measure the locations of all the mounts on the frame and all the mounts on the cab/fenders and calculate the necessary shims for that particular combination of parts, but given the flexibility of the parts and the complicated geometry, I do not believe it would be any faster or more accurate than determining it experimentally.
I think the most valuable bottom line takeaway from my experience here is that improperly shimming the front of the cab can cause door frame deformation that prevents the doors from closing properly. | | | |
Entire Thread
Replaced cab mounts, doors won't close...
| Fibonachu | 01/26/2025 4:37 AM |
Re: Replaced cab mounts, doors won't close...
| klhansen | 01/26/2025 8:21 AM |
| 78buckshot | 01/26/2025 10:12 AM |
| Otto Skorzeny | 01/26/2025 2:03 PM |
| Fibonachu | 01/26/2025 7:17 PM |
| klhansen | 01/26/2025 10:53 PM |
| Fibonachu | 01/26/2025 11:05 PM |
| Otto Skorzeny | 01/26/2025 11:38 PM |
| Gib70 | 01/27/2025 1:40 AM |
| Gib70 | 01/27/2025 1:46 AM |
| Fibonachu | 01/27/2025 3:32 AM |
| Gib70 | 01/27/2025 2:44 PM |
| Fibonachu | 01/27/2025 3:42 PM |
| Fibonachu | 01/28/2025 7:12 PM | |
