The higher psi dual stage also really helps out with air tools .An impact wrench really works so much better at 175 psi easily devoloped by a dual stage.Some of the lower priced single stage compressors may be rated at 5-7 HP but may not move as much air as older 5 HP single stage models in my opinion.
