1 members (216wny),
70
2
Mod | | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2017 Posts: 8 'Bolter | | 'Bolter Joined: Nov 2017 Posts: 8 | Recently got the truck running again. Seems to be running fairly good. i noticed that it is running rich. any list of reasons that could be making it run rich? secondly, when you change from 6volt to 12 volt, do the spark plugs need to be changes due to higher voltage?
thanks for your time as always!!
Oldtruckspapa
Blessings, Oldtruckspapa
