If you have a small DA sander, I'd use that. Even a Harbor Freight one link should work that long. You might consider removing the strips (maybe one or two at a time) so you can get right to the edge. The stuff I used is pretty thin, so should get under the strips if you don't remove them.
Kevin
1951 Chevy 3100 work truck
Photos
