Waveski, when you had the intake off and on several times, what was the configuration for the exhaust crossover ports in the intake gaskets? Many intake gasket kits include several steel inserts so you can tailor the amount of exhaust heat crossing under the carburetor from one head to the other. If those ports are wide open with no restrictor inserts, it will add a huge amount of heat to the manifold and carburetor.
1957 Chevrolet 5700 LCF 283 SM420 2 speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto, 1978 Yamaha DT175, 1999 Harley Davidson Softail Fat Boy
