| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | The design of the early stovebolt hydraulic lifters did not provide a pathway for trapped air to be purged from the lifter bore. Later designs used a tiny pinhole in the pushrod seat to allow for a small leak to happen, which allowed the trapped air to escape much more quickly. I have seen several modification procedures to the lifter and the bottom of the pushrods suggested to create a very small amount of leakage to accomplish that kind of air displacement. BTW- - - -Lincoln Zephyr V-12 engines in the 1930s and 40s also used a very primitive design of hydraulic lifter, and they had similar problems with noisy lifters on a cold start. Jerry
