7 members (Uncles51, baldeagle, 1955 1 Series, 50Chevy3100, Gray_Ghost, Maybellene, Shaffer's1950),
121
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,002 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,002 | Otto, like Chip said, only two bulbs in the gauge cluster, and only 2 illumination bulbs in the speedo, plus the one for high beam indicator, which is on a different circuit. So the 4 illumination bulbs for the cluster and speedo, plus the one bulb for the ignition switch are all that should be on the harness that you're going to connect into the taillight terminal. I doubt that the difference in wattage between the 55's and the 51's will overload the switch capacity. Even with the 51's, the white paint inside the gauge cluster got toasted a bit over the 70 or so years they were in there. The 55's might darken the paint a bit more than the 51's if that's a concern.
