| | | Forums66 Topics128,110 Posts1,056,251 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,689 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,689 | Kind of an unanswerable question without knowing HOW you wired your truck.
But it might be pretty easy to have a functioning ammeter. All the LOAD stuff goes on one side of the ammeter. And the other side is just a direct connection to battery.
To oversimplify it….
If you used some sort of fuse panel, you need to feed it from that load side of the ammeter.
But a better way to answer your question is to have you describe your current state.
1951 3100
