7 members (Hotrod Lincoln, 46 Texaco, tclederman, papas52, dt235sd, MNSmith, 55shaker),
133
0
Mod | | | Forums66 Topics128,162 Posts1,056,913 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2023 Posts: 443 'Bolter | | 'Bolter Joined: May 2023 Posts: 443 | Do you have a 3 or 4 speed transmission.. On my 54 3100 I had a 4 speed and it didn't have clearance to drop down. I had to raise it and remove the rear yoke. It hadn't been off in 70 years and was a tough one.. had to use a chain and pully to get it out.. I then had room to lower it and get the rest of the stuff off the shaft. Then thanks to input on here I raised the torque tube up and ran a 2/4 across the frame to support it up and out of the way and safe from coming down..
If you have a 3 speed you should be fine as for as clearance goes and can lower it down and remove everything.
Doug 1954 Chevy 3100One problem solved doesn’t seem to shorten the list Montgomery, ALIn Project Journals | | |
