7 members (cmayna, 55shaker, Gray_Ghost, Otto Skorzeny, Hotrod Lincoln, MikeE, 1 invisible),
131
3
Mod | | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 4,499 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,499 | I would try bleeding the rear brakes again, this time with two people, (open bleeder then push pedal to floor, close bleeder then release pedal, repeat), so you can verify you have no air in the system before I did anything else.
When you leave it open while pumping, you may just be sucking the air back into the system when you let the pedal back up.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | |
Entire Thread
1969 brake master cylinder, drum/drum
| Woogeroo | 11/15/2024 4:05 AM |
Re: 1969 brake master cylinder, drum/drum
| Otto Skorzeny | 11/15/2024 4:22 AM |
| KEVINSKI | 11/15/2024 4:35 AM |
| Phak1 | 11/15/2024 12:55 PM |
| Otto Skorzeny | 11/15/2024 1:32 PM |
| Hanks custodian | 11/15/2024 4:34 PM |
| Hotrod Lincoln | 11/15/2024 10:37 PM |
| Woogeroo | 11/15/2024 11:31 PM |
| Woogeroo | 12/25/2024 1:01 AM |
| klhansen | 12/25/2024 2:05 AM |
| Woogeroo | 12/26/2024 3:59 PM | |
