Enclosed is a picture showing 1.375” x 14” disc assembly from GMC P-3500 HD truck mounted, kingpin out, on my ‘55 two ton truck. Looks exactly like Rich’s application. Larger disc, similar applications, as suggested in text appear to be possible, with minor machining and fabrication required, caliper bracket in particular. Air in system(HRL) allows pieces to be clamped together for design and marking.
Enclosed assembly is essentially a bolt up (Grigg), only fabrication required is new kingpin bushings($12.00)
Ed
'37 GMC T-18 w/ DD 4-53T, RTO-610, 6231 aux., '95 GMC running gear, full disc brakes, power steering, 22.5 wheels and tires. '47 GMC 1 ton w/ 302, NP-540, 4wd, full width Blazer front axle. '54 GMC 630 w/ 503 gasser, 5 speed, ex fire truck, shortened WB 4', install 8' bed. '55 GMC 370 w/270, 420 4 speed, grain, dump bed truck from ND. Works OK.
