| | | Forums66 Topics128,279 Posts1,058,582 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | The last torque-tube powerglide would have been 54. It was cast iron. I wonder if by some stroke of luck GM didn't change the tail-shaft bolt pattern when they went to aluminum. I also know the dry lakes boys like cast iron PGs because they are strong and don't use much power. There are lots of aftermarket power glide parts or there were last I looked, which is maybe 10 years so its possible that one could adapt an aftermarket cast Iron one to a torque tube but probably not inexpensive. all depends on parts interchange, which I'm no expert. Maybe put a post in the Hi Po forum. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | |
