Hi Chuck52, I would carefully inspect the square end of the cable and the square hole in the transmission gear to make sure they fit snug, could be one or the other is worn to the point of not spinning the cable, also make sure that the cable nuts are snugged down all the way, that is what holds the cable ends in the speedo head and transmission gear. Color near Alpena was very close to peak last week, I probably won't have a chance to go back north until all the leaves are down.
1957 Chevrolet 5700 LCF 283 SM420 2 speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto, 1978 Yamaha DT175, 1999 Harley Davidson Softail Fat Boy
