| | | Forums66 Topics128,181 Posts1,057,191 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | What I use. At $6.19 a quart the price seems fair. One tip, this stuff is flowable, but SLOW. I put the plastic bottle in a pan of water and turn the heat on low. About the time the water starts to bubble it's ready to head to the shop and fill the steering box. Without this step, you'll squirt a couple thimble fulls into the steering sector fill hole, it'll look full, it's not....take a screwdriver, stick it in wiggle it a bit and when you pull it out the 00 grease will slowly ooze down, keep repeating all the while asking....Why did't I just heat it up? Good Luck, RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
