The alternator grounds through its case. So just make sure the mount is clean where the alternator touches it and where it touches the block.
Do you have a good frame->block ground wire already? If not, this would be a great time to add one.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
"Frank" gets a new lease on life
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
The Saga in the DITY Gallery ~ and the story continues
