| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | What's the battery terminal voltage while trying to crank with the plugs in? It sounds like you've got battery trouble, not a tight engine. What amperage did you load test the battery? Jerry
