| | | Forums66 Topics128,130 Posts1,056,712 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | Not sure on which goes where on the door frame. I did look at the catalog and see that one of the conical bumpers is definitely larger around and taller than the other. One way to figure placement out is to get a chunk of clay or similar compressible stuff, form a ball and stick in each corner bumper spot. Gently close the door until it is flush with the cab edge, then open back up and see which glob got crushed more than the other. You should be able to judge which spot gets the larger and which gets the smaller bumper then.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
