Be cautious about using penetrating oil around brake parts. Petroleum based penetrants and brake rubber parts like wheel cylinder cups don't play well together. It also contaminates brake linings. Silicone type penetrants will be a little safer than using something like PB Blaster. Using a little bit of persuasion from an electric heat gun or a Propane torch, with the brake drums removed, plus the silicone penetrant is by far the best way to free up any sort of sticky brake hardware.
