PS; Make sure your wiring is up to the task. I replaced all the wiring from the lamps to the dimmer switch with 12ga wire and good connectors.
If your wiring is original, it may be worn out, corroded, or whatever.
1950 Chevrolet 3100 (Ol' Roy)
