| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | Go one step further and remove the intake/exhaust manifold assembly and the freeze plugs on the driver's side of the block. Then pressure wash between the cylinders with the high pressure wand pointed toward the bottom of the water jacket. Wear a rain suit and a face shield- - - -the blowback will be epic. Replace the pressed-in freeze plugs with the rubber expansion type. Jerry
