0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15580 07/12/2003 1:43 AM | Joined: Apr 2003 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 140 | Welcome to the Stovebolt! You've got quite a project cut out for yourself. You're right, you will need some help.
No 454, or any other big block, fits. Small blocks will fit, especially if your truck came with a 283. If not, get the motor and tranny mounts from one that did, and go that route.
Stuffing a big-block in means a lot more welding and fabricating and parts-fitting, etc. - and $$$, too. Figure on serious money. The big-blocks are also much heavier, which won't help handling much.
I'd suggest stuffing in a serious small-block. You'll wind up with more performance with a good small block, than a hacked-and wedged BB.
Good luck! George | | | |
Entire Thread
Needs specs on engine info (year, bolt, etc)
| rstardark | 07/11/2003 10:41 AM |
Re: Needs specs on engine info (year, bolt, etc)
| George Grenley | 07/12/2003 1:43 AM |
| rstardark | 07/13/2003 12:07 AM |
| GrannyLow57 | 07/13/2003 12:30 AM |
| George Grenley | 07/13/2003 5:09 AM |
| rstardark | 07/13/2003 8:52 AM |
| popcorn3023 | 07/13/2003 1:10 PM |
| rstardark | 07/14/2003 11:20 AM | |
