8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC),
104
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | "Carbon Pile" load testers are the only ones worth buying. They have a big stack of carbon resistor plates several inches square, and an ACME thread screw to compress them together. The good ones will have a carbon pile capable of applying up to around 1000 amps of load to a battery, which is more than the CCA rating of anything but a heavy duty Diesel truck battery. Anything else is just wishful thinking where battery load testing is concerned. A good load tester will cost around $200.00 or a bit more- - - -it's worth it! The price jump between 500 amp and 1K amp is pretty noticeable. www.ebay.com/itm/164885207331?Jerry
