| | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,957 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,957 | Tommy, hold on. The damper in my picture is from a '66 Mustang. I just posted it for reference because it's the only style I'm familiar with.
52Carl describes the Chevy unit as being a sandwich stacked perpendicular to the crankshaft axis and impossible to slip and separate like the one I posted. I just wanted to make sure that I understood him correctly.
In any event, I removed the belt and the balancer is intact and not coming apart. I actually was hoping that I'd find the sheave spinning on the hub - easy fix, but no luck there.
My balancer is probably original to the engine. Crank snout also has the hand crank provision.
1950 Chevrolet 3100 (Ol' Roy)
Entire Thread
216 Water Pump, T-Stat, and Other Cooling system Questions
| Otto Skorzeny | 07/17/2024 5:22 PM |
Re: 216 Water Pump, T-Stat, and Other Cooling system Questions
| Hotrod Lincoln | 07/17/2024 5:43 PM |
| Otto Skorzeny | 07/17/2024 7:22 PM |
| Otto Skorzeny | 07/18/2024 10:01 PM |
| Hotrod Lincoln | 07/18/2024 10:40 PM |
| Otto Skorzeny | 07/25/2024 11:17 PM |
| Bill Hanlon | 07/26/2024 2:43 AM |
| Otto Skorzeny | 08/09/2024 9:47 PM |
| Otto Skorzeny | 08/10/2024 3:16 AM |
| Otto Skorzeny | 08/11/2024 4:40 PM |
| 1Ton_tommy | 08/12/2024 4:32 PM |
| Otto Skorzeny | 08/12/2024 10:35 PM |
| 52Carl | 08/13/2024 12:36 AM |
| Otto Skorzeny | 08/13/2024 12:46 AM |
| 52Carl | 08/14/2024 12:37 AM |
| Otto Skorzeny | 08/14/2024 1:55 AM |
| KEVINSKI | 08/14/2024 2:12 AM |
| Otto Skorzeny | 08/14/2024 2:17 AM |
| KEVINSKI | 08/14/2024 2:26 AM |
| Jethro in Va | 08/14/2024 9:29 AM |
| Otto Skorzeny | 08/14/2024 12:30 PM |
| Mike B | 08/14/2024 4:08 PM |
| Otto Skorzeny | 08/14/2024 4:29 PM |
| Otto Skorzeny | 08/17/2024 3:26 PM |
| ol 55 | 08/17/2024 4:22 PM |
| Gdads51 | 08/17/2024 3:51 PM |
| Otto Skorzeny | 08/17/2024 4:25 PM |
| Otto Skorzeny | 08/17/2024 4:26 PM |
| No1300 | 08/17/2024 11:05 PM |
| ol 55 | 08/18/2024 11:56 AM |
| Otto Skorzeny | 08/18/2024 12:29 AM |
| Otto Skorzeny | 08/18/2024 12:25 PM |
| 52Carl | 08/18/2024 2:34 PM |
| Achipmunk | 08/18/2024 8:34 PM |
| 1Ton_tommy | 08/20/2024 6:38 PM |
| Otto Skorzeny | 08/20/2024 6:58 PM |
| Otto Skorzeny | 08/20/2024 7:14 PM |
| Otto Skorzeny | 08/20/2024 8:46 PM |
| 52Carl | 08/21/2024 12:45 AM |
| Otto Skorzeny | 08/21/2024 1:13 AM |
| 1Ton_tommy | 08/21/2024 11:11 PM |
| Otto Skorzeny | 08/21/2024 11:17 PM |
| TUTS 59 | 08/27/2024 12:22 PM |
| Otto Skorzeny | 08/27/2024 12:33 PM |
| Guitplayer | 08/27/2024 1:28 PM |
| Otto Skorzeny | 08/27/2024 1:39 PM |
| Guitplayer | 08/27/2024 2:49 PM |
| Otto Skorzeny | 08/27/2024 4:18 PM |
| 1Ton_tommy | 08/27/2024 4:54 PM |
| Otto Skorzeny | 08/27/2024 5:16 PM | |
