I sent pictures of my shifter. Was wondering if you could measure the length from the bottom of the ball to the bottom of the shifter? Also how thick the and or wide the end or as I called it a “T”. The rounded part at the bottom. Kinda hard to describe. Sorry. Thanks so much for your help. It’s shifted fine for 10 years although it’s driven mostly on weekends to avoid the crazy traffic where.
