| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,782 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,782 | Try adjusting the idle mixture the way I learned to about 60 years ago- - - -turn the mixture adjusting screw clockwise (lean) until you see a drop in manifold vacuum, then back it out until the vacuum maxes out. Some people claim that the acceleration just off idle improves if the mixture screw is set about 1/8 turn richer after the max vacuum is achieved. Unless you have a leaky intake valve, that should stabilize the vacuum and eliminate the slight pulsation of the gauge in your video. I've seen Pertronix triggers that can be moved on the distributor cam a little, which results in inconsistent ignition timing between cylinders. A drop of RTV gasket sealer between the cam and the trigger wheel might help avoid the error. Jerry
