| | | Forums66 Topics128,126 Posts1,056,353 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,810 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | One bad diode will cut an alternator output to less than 1/3 of its rated capacity. I've seen a "65 amp" alternator produce less than 10 amps max while still producing normal regulated voltage (14.5+) It would keep the battery charged during daytime operation, but drain the battery with the headlights on. An electric fan will do the same thing- - - -draw more amperage than the alternator can produce, and grab the excess current from the battery. Voltage is only one leg of a 3-legged stool- - - -the others are amperage output and load. Have your spark chaser do a "full current" check on the alternator if he knows how to do that test. Jerry
