| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | It's also possible to run a dummy mechanical pump with the internal parts removed, and drill a couple of extra holes in the crankcase near the oil pump for full flow oil filter lines, if you want a less efficient method of cleaning up the oil than a bypass filter. Jerry
