0 members (),
93
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,762 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,762 | Are you relying on the dashboard gauge? If so, don't.
Install a temporary gauge under the hood so you can see what the true pressure is. You can also remove the valve cover and/or side cover to see if oil is flowing around the engine.
1950 Chevrolet 3100 (Ol' Roy)
