| | | Forums66 Topics128,060 Posts1,055,831 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | At the rear end of that tube behind the side cover there is a fitting that screws into the block. That fitting has a 1/16” hole in it to restrict oil flow to the rocker. I think by drilling that restrictor out to around 1/8” you could use the offset rockers and a center supply tube that doesn’t have the loop that allows oil to escape. That style was used up to 1958. You need what is often referred to as the pinched off style that started in 1959.
See the USA in your vintage Chevrolet! My Blog | | |
