| | | Forums66 Topics128,203 Posts1,057,286 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,879 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,879 | Good looking work! That's pretty similar to the way we adapted various disc systems to the round track cars, and it was pretty common to use rotors and calipers from different makes of vehicles. Here's a sneaky trick for anyone who is considering tackling such a project. Once the hub and rotor are married up and the hub is mounted onto the spindle, use air pressure to clamp the caliper and pad assembly to the rotor and tighten up the spindle nut enough to keep the hub from turning. It's a handy "third hand" while you're making up those templates for the caliper mounting bracket. Jerry
