2 members (LAROKE, baldeagle),
63
3
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | That flywheel can be used on both a car and truck with a 235 engine. A 9.5 clutch was used on a 6 cylinder car. Most 6 cylinder trucks used a 10" unless it was a HD application. That appears to be drilled and tapped for a 10" clutch. An 11" would have the bolt holes closer to the ring gear. You want a flat diaphragm clutch with the long bearing. Most parts stores will try to sell you something else but it won't work. Fred
BTW. Not all Tri Five Chevy cars are Bel Air's. The car that was most produced and sold in those years was the 210 four door sedan. There were also more 150 models sold than Bel Air's. A wide assortment of engines and transmissions was available for all models.
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
