| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | The 913 head casting was used on 1954-56 235 full pressure oiler engines. It has a slightly lower compression ratio than the 848 head(56-63) but it can be milled .090" to equal the 848 compression. Recess the intake valves back into the head the same distance to preserve the "quench trench" that keeps the valves from burning if you choose to mill that head. Either head will be a bolt-on fit to pressure oiler 235s or 261 engines. Jerry
