7 members (TexasJim50, DadsFirstPickup, 54farmtruck, Patharr, klhansen, Pete1946, 1955 1 Series),
114
Mod | | | Forums66 Topics128,148 Posts1,056,811 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,848 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,848 | The pressure a pump produces depends on the strength of the return spring. The cam lobe simply creates the suction to pull the gas from the tank to the pump- - - -the tension of the spring determines the fuel pressure the carburetor sees. Those super-stiff springs some manufacturers use will overpower the needle valve in the carburetor by developing 10 PSI or more of fuel pressure, instead ot the 2-5 PSI the carb is desined to get. That's why doing a pressure and vacuum test on the newly installed pump isn't just a good idea- - - -it's something I do just about all the time! Jerry
