| | | Forums66 Topics128,147 Posts1,056,806 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,846 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,846 | As long as the multi-piece arm contacts the cam across the full width of the face, no problem. I'd use a little Prussian Blue indicator dye to check the cam contact footprint, and correct it with a fine grit belt sander if necessary. Are you smarter that the 12 year old slave laborer who put the pump together in some third world sweatshop? Jerry
