Also, note on those switchs ING 1, and ING 2 are not the same.
When you were turning to the start position, the solenoid and ignition 2 only will have power. ignition 1 and a aCC will not.
When in Run position. ACC and ignition 1 and ignition 2 will have power
In aCC only aCC will have power.
The starter wire solenoid on sol. Purple
Dark green on ing 2
For it to run minimum
Gauges on ing 1 or 2 pink
Red on bat
