| | | Forums66 Topics128,052 Posts1,055,738 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | On my 51 Chev PU, I plumbed in an air tank for a semi-trailer with check valve coming off the manifold. The vacuum end went to the hydrovac, wipers and AC vacuum actuators and for a while to the manifold side of the fuel pump vacuum booster. This worked fine until the wiper motor wore out and I didn't have enough good parts to fix it. The fuel pump eventually began sucking prodigious amounts of oil and so did it's replacement only a short while later. I gave up on mechanical fuel pumps and went electric -- wipers and fuel pump. Only trouble since has been a failed electric fuel pump that cost me a tow off the freeway. Wipers work well. Get the delay switch. It's worth the price.
I long ago had a 50 Stude with vacuum wipers. It came to me with a vacuum tank screwed under the floor and a check valve. It worked tolerably well on short hills in town but on the road I would have to lift my foot off the gas pedal to recharge the tank every so often. Eventually I found a vacuum boost fuel pump and took the other stuff off. I drove it daily for ten years in rainy Seattle. Wipers worked fine when I sold the car years later. I still have the check valve. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | |
