Thanks Virginiafiretruck, I enjoyed your pictures as well, awsome restoration. If I'm able to do half the job you're doing I will be very happy.
Very nice mounts Scott, thanks for the picture!
With all the torque from the Stroker,will the trans be fine just using the 4 bolts(grade 8) holding it to the bellhousing and just hanging in the air like orriginal or should I make a mount for the trans as well?
