If it was leaking there, it might be leaking elsewhere. I would recommend checking all of the fuel line fittings in the system.
That said, if it still leaking, then it is either not tight enough or the fitting is damaged.
Pulling it apart and carefully inspecting both sides would be another good choice.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
"Frank" gets a new lease on life
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
The Saga in the DITY Gallery ~ and the story continues
