| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | The truck front mount is a rectangular rubber and steel assembly that bolts to the flat bottom of the steel separator plate between the engine block and the timing gears. It might be necessary to drill that plate for the mount attaching bolts. Some are drilled- - - -others aren't. Use the mount as a template to locate the holes. Jerry
